hey
So the french thermostat i've replaced 4 months ago was failed
Yesterday i've changed it to the Renault OEM one with new coolant tank (the old one had a leak)
Of course that i've replaced the seals both times.
The car still doesn't warm up like he should, starting up on IDLE 15 minutes from cold engine, the temp doesn't pass 75C
The bottom hose from the thermostat to the radiator DOESN'T warming up before 12minutes (when the OBD shows about 70c) so i'm not sure those stats are both failed
Any suggestions ? i think that i've made the air drainage well (from the screw)
Thanks...
Thanks...
