1.5 DCI fuel pump
Car  clio
K9K fuel pumps are always coming up on the forums and I want to pick your brains.
I have a clio diesel and want to remove the uplift pump side of the pump and use either a single pump or 2 pumps to get the required pressure which is 5 bar to operate.
With the 2 pump system was thinking of tank, external filter then 3.5 bar pump, 1 way valve into the engine bay to another main filter/ water separator, then 6 bar pump to the Diesel pump.
Was thinking of a adjustable regulator & then returning the line back to the tank, as you know there is not to much room in clio's lol
