1.8 16v engine problem
hi all, new to this forum. looking to get a clio 1.8 16v to do a bit of track racing in and have found one i like but there is a problem with the engine which im not to sure about. hopefully someone can pin point it for me.
(quote from seller) *the car runs fine but wont drive anywhere due to gearbox problem. you can go up through all the gears but not go anywhere, even the speedo works that indicates the box works. recently informed that this common to clios and may not be the gearbox, possibly a circlip failure on one of the driveshafts *
sorry to ramble on but any information on possibly what it is would be grateful. thanks in advance
aaron
Yep sounds like the circlips gone easy to change them if your lucky can take ages if your not just the way it is only a few quid for the parts.
extremely common. Happened to my valver not long ago. Quite easy to fix, and like edde says, cheap part.
edde;2987640 They hold the differential togtehr when they brake the dis isn't help together so no power goes.[/quote said:
ahh thankyou. i take it you can get these from local dealer or similar.
thou 110 on the driveway sounds funny!!
yep special order part so takes a few days get a Haynes shows you where they are etc I think there 4 best chnage them all though regardless.
