1.8 16v idle problem
  Nissan 200sx S13
my car idles irracally, it sometimes idles at 1500rpm, then at 1100rpm, am i right in saying it should idle at about 800rpm
Also when you accelerate hard,and then put the clutch down the revs stick at about 3300rpm.
It has kent cams in it, could the problem be the idle control valve, or maybe an air leak.
How do i go about fixing these problems, there seems to be i whisting noise coming from below the plenum passenger side but i cant see anywhere ythat looks like an air leak
ive also tried cleaning the idle control valve with electrical contact cleaner. but with no help
  Skoda Fabia vRS
did you clean the inside of the ISCV ?.....did any crap come out
problems with revs sticking high are usually down to the speedo cable behind the clocks being poorly earthed
check the hose connected to the manifold that goes to the map sensor
check the hose coming from the ISCV into the airbox is on properly
  Nissan 200sx S13
its got a K+n but it should idle without the still, just with unfiltered air.
I take it the ISCV is the idle control valve.
When you cay manifold, i take it you mean inlet manifold, the hose is connected alright.
the map sensor is not mounted anywhere though, its just sort of hanging there.
