120mm trumpets in Ktec bodies
Anyone using 120mm 45mmID trumpets in their KTEC DTH bodies WITHOUT angle
Modifications?
I understand you will need to trim bonnet and use a larger filter.
Taking measurements from the current bodies with 90mm trumpets and total length from head to end of trumpet is 280mm, that only gives 30mm of clearance left for filter as single skin bonnet (taking into account 20mm void needed inside of filter and end of trumpet).
Better off sticking to 90s?
There isn't much space, if any but it doesn't seem to matter in this case. It is only a small area that doesn't have the "specified" clearance. The car won races with it like that.
When I get it dyno'd I will try it bonnet open and closed to see if it makes any difference.
