16v clio kinocking noise puzzled
ok,
story i have a 16v clio with a willy lump in which is re-con (4000 miles)
gearbox rebuilt 3000 miles ago
in the last six month it has had new
steering rack and column
bearings all round
ball joints
struts and springs (-40mm)
discs and pads, starter motor, alternator, pas pump, brake hoses
the car has done 110k though
i have been getting a knocking noise for about 3 week now, when travelling in a straight line upto 70 no noise, after 70 vibration through the footwells and car sounds like a helicopter if sitting at say 80, but if at any speed above 70 i accellerate the vibration goes away until i sit at a constant speed or slowing down (bangs like mad), when changing lanes left to right no noise at any speed, right to left at any speed banging knocking and clicking, could this be the cv joints or drive shafts, if so will drive shafts off a 1.9d clio mk1 fit a 16v
if changing
sounds fun..............do you get a knocking or clunking noise if you put the steering on full lock & drive round in circles ?? (both ways)
You say you have replaced bearings all round. Take it you mean wheel bearings as when my front passenger side bearing went it made a noise like this at aboout 60-70.
Sounds similar to mine!
My valver makes a clunking noise and when car is in drive slowing or accelerating. Ive had one driveshaft replaced and all bearings so far but my dogbone engine mount is also broken/rubbers perished - getting fixed right now so will let you know if this cures it.....
