172/182 Gear knob
I thought that they were bonded on but it turned out that the gear stick actually has diamond cut knurling around the top 2-3cm. The white shroud you see in the last picture is then pressed onto the stick. It took about 45mins of prying with a small screwdriver and twisting to get it off.
any ideas about the ph1's as i have always prefered the round metal one they have fitted
Just fitted one to my replacement stick. They are just a machined aluminium ball so can only assume they are bonded somehow from the factory. Not sure how you would remove one though without damaging it.
