Hi Roamer it can be done with out taking the bumper off.just undo the clips that hold it on and push it back. you will have jack up your car to get it out from under the car i hope this helps.ps its looks the dogs nuts when its done ally mesh
Yes you can. Had mine off today. It is a bit of a squeeze. If you look underneath the car there are two bolts that hold on the black plastic thats joined to the bumper. If you take these out you can just about wriggle the lower grill out from underneath once you have unclipped it.
Not me. I gave up with the mesh I had (stuff like on the new MGs) cos 1 it wasnt long enough to totally replace the bottom grill and 2 it is soooooo tough to cut. So just ended up putting the grill back in.
Nice one Wayne, Ill have to have a look, cos Ive just cut out the non-open squares on the right hand side, ready for the viper, but once its in, I wana mesh it up and fit the pipe end into the mesh ;-)
Ill have a go at taking it out once Ive found a good mesh (And got plenty of it)
IF YOU ARE AT BRANDS FIND ME. FD02 W** REG I CAN TALK TO YOUR THERE UNLESS YOU ARE DOING IT BEFORE THIS TIME THEN PM ME AND I WILL GO THROUGH IT WITH YOU.
hey roamer, wot do u mean by "cut out the non open squares" mate for the viper? i had mine put on at k-tek {lazy fecker} so hadnt looked at that maybe, cheers.
