172 Climate Only Blows Hot!
Car  Porsche 996 C2, Clio 172
Hi guys.
172 climate started blowing hot when on the minimum setting the other day. Didn't matter what I did with the settings, they all still work, and the screen displays the full range of temperature settings, but it would only blow hot!
The last 3 or 4 days it's been fine again. It's usually on minimum with first 3 or for bars of fan and works fine.
However, the missus was sat in the car a couple of hours ago. She started the car from warm, put the climate on full, coldest setting and recirculate and after 10 minutes it started blowing only hot again.
Tried turning the system off and on again, engine off and on again but still blowing hot only.
Anybody else had this problem and know what the fix is?
I suppose it might go back to normal again once the car's cooled down.
Any ideas gratefully received. Thanks!
