172 cup dead when starting
ADS_V6
Car  172 cup clio v6 st
Hi when to start the cup an hour ago and it was dead,not like flat battery or left lights on,it was like the immobiliser wasnt unlocking
I then waited a bit sat in car and used the key to lock and unlock and it started,then as i shut the engine off and restarted it was cranking but not firing
Now been out and about and car is fine,immob light is not stuck solid
Any help im clueless of what to check
hi it goes out on turning the key flashing as normal without key in,what is strang is i cant always hear the fuel pump priming on position 2
hi its a new battery on the car,odd again its starting up fine now but off and on the fuel pump noise is not there every time
