172 Cup Not Starting.
Car  172 Cup, R34 GTR
Hello all,
MY first post and i was hoping it would be in the projects section, DOH!
Since owning my cup i have had intermittent starting issues. It seems to have given up all together tonight.
The car will not start when the orange electronic fault light is lit. It turns over without cutting out but just wont fire. Fuel pump seems to prime. Before tonight simply turning the ignition on and off a few times would make this light go out and the car would start straight away.
The service and airbag light are sometimes lit but not always when the issue occurs.
I have re terminated the TDC as there was a loose connection, relays look ok ie no corrosion.
Have been searching and have found a lot of threads about the immobilser light but not this one, unless i am mis understanding something- highly likely:clown:
Asked Renault to check it when it was in for a service but they found nothing.
Does anyone have any idea where i can start looking?
Thanks in advance
Main control relay is a good place to start looking and simply jump it out to see if it solves the issue.
Mick
