172 cup tuning
Car  clio sport cup 172
need a bit of help,got a hillpower induction kit,decat pipe,k-tec exhaust, group n ecu,want more power!! whats my next move ? anyone got any advise cheers.
does it give advantage when having the 182manifold going under the the subframe instead of the 172 mani going up over the subframe ?
for example easy fitting sportscat/decat and back to original when Mot ?
if you want to listen to the bullshit then await the posts on here, or just pm me and here the truth! for the record i'm now free lance
if i fit 182 manifold, i will have to fit 182 de-cat pipe also,? will that fit straight on to my k-tec exhaust, what sort of power increase can i expect ? IS MANIFOLD EASY TO FIT
You need to drop the subframe a bit on one side to swop the manifolds
You have to either get a Cat/decat etc made up to fit as the 172 or 182 won't directly fit most people seem to like the cut up 182 one made to fit.
Gains with mapping are smalla about 5hp mayabe depends on other mods and mapping etc.
Its a pain to do regardless hence why IMO use a 182 cat.
