Any idea where I can find the engine nos on my Mk2 172? Apparantly it starts "F4R..." but, even after looking in the manual (which tells you where to look) I cant see anything that resemlbes an engine nos.
Help!
P.S. Im after the nos so I can order a Group N ECU!
Apparently its really hard to spot, not sure where tho, people have asked before and the best response seams to be take it to a dealer and get them to show you.
at the bottom of the block - it will start F4R then there will be 3 letters and directly underneath that there will be a 7 digit number starting with a letter and then 6 numbers. This is your engine fabrication number - it tells you when your engine was built at the plant and what type of 2.0 lump it is - its only any use if you have a dialogys program on your pc. Type these numbers in and it will give you 100 % accuracy when ordering parts.
