172 Engine replacement - Power issues
Car  Clio 172 Cup
Wouldnt crank over at first, all fixed by replacing the three brown relays on the fuse box, but there is no power to the coil pack, and the fuel pump doesnt run unless i bridge the pins on the relay socket, the relay itself is fine. Not sure what the other big brown relay is for, or the purple one next to it. I'm guessing there is a common issue for both not to work, i'm getting 12v to the injectors.
