172 exhaust
different diameter pipe so you would need to install a reducer. however the increased bore will make it sound like a tractor.
i did this......although i had the backbox which had a massive bore from a 172.....i had to have a center section made up that expanded out to the right bore.....although because of this you loose power and it dosent sound as good as it could
