172 fuel rail questions
Car  C63 AMG, F430 & 172
I have a Y plate psh1.
It didn't have the line going from the pressure reg to the T/B and it had a space for a regualtor rather than the metal regulator being in the slot.
Ive lost the old rail and injectors.. can I use any rail off a psh1/ps2 aslong as it doesn't have a reg in the rail?
yep. late ph1s have the regulator in the pump like the ph2/3. should be double oxygen sensor ph1... rail dimesnion are all the same, you should be fine!
Sweet, one other thing. When the carbon canister has been removed, the return to the tank is just unplugged (where it joins under the drivers footwell)
Is this ok or should I block it?
