172 mk2 exhaust and decat on a mk1
Old ktec racing 172 mk2 exhaust with decat.. Will it fit on a mk1 with no problems?
Is this for me?..
If so..
The exhaust is the older stealth system from around 2009 on a Ph2 with a ktec decat.
Would like it for my Ph1 so wondered if becasue it has the sleeve on the cat back part it will slide a little further to fit in length?
The decat has 1 lambda sensor with the other covered.
Thanks alot
Liam
Are we talking about a mk1 clio or a mk2 ph1.
If you are on about a mk2 ph1. Then if you have the decat and catback of a ph2 then they should fit.
You will only run into problems if using an early ph1 cat as it's shorter.
Fitment to a mk1 clio. I doubt it
It is a Mk2 Ph1
Its an X reg Ph1 but if there is the decat doesnt that take away from the problem of the cat being shorter?
It is a Mk2 Ph1
Yea that's what I'm saying. If you have the ph2 decat you won't have a problem. Should go on fine mate
