172 not reving past 5000rpm
Car  Clio 172
Hi Guys wondered if anyone could help with a on going issue I have with my clio 172 phase 2 2006. It's been to Beaniesport for a new cambelt and timing. but prior to this it hasn't reved past 5000rpm. it's had timing done dephaser pully, water temp ,water pump, vvt solenoid, air temp and air flow sensors and both lamba sensors changed and the issue hasn't changed. when ever it has been to a garage it works fine for around 80miles then goes back to not reving past 5000rpm under load. no engine lights come on apart from the serv light but I have been told this is because it has no airbags connected. please help it's driving me insane and been going on now for 8 months. it drives fine under 5000rpm but as soon as you reach that point it just splutters
Also don't know if it's linked but when I did a track day with it on long right handers it would bog down and have no pull until back on the straight again.
I was thinking the same but why would it run fine for a few days once I picked it up from a garage then goes back to not reving. If it was fuel issue wouldn't it do it all the time?
