172 not starting after dashboard lights flickering
Car  172
Hi guys my clio let me down for the first time ever today. At first all the dash lights were flickering/ dim and the car wouldnt even turn over but I then cleaned the battery connectors and the lights went back to normal and the car would turn over 3 or 4 times but not start. The AA came out and the guy wiggled some cables switched some relays about and tried reconnecting the battery with the ignition on position 2 he done all of these things a few times but to no avail. He said its probably a bad connection or a loose cable and reading other threads this seems about right. Does anyone have some other ideas or happen to know which cables/connections its likely to be?
Cheers :)
Car is fixed connected it to a cheap obd II scanner and cleared 3 fault codes P0325, P0202,P0314.
