172 rear disc help
Car  clio 172
hi all
i have just got some new grooved rear discs for my 172 (52)
they do not come with the bearings pressed in do you think i will be able to reuse the old ones?
do you think they will come out of the old discs easily?
thanks
si
hi all
thanks
si
best off getting new bearings mate, they dont comeout easy.
you can reuse the old ones i have done it on my own cars in the past but i wont do it for customers as pressing them out tends to press the grease out of the bearing and it shortens its life a fair bit
and cutting the disc takes too long
plonking it in the disc positioning it on the press and pulling the lever a few times
takes 2mins including a tea break
This is not for the home mechanic unless you have a press in the corner of your garage. Buy the bearings from your local factor for £20 then ask a kind local garage to press them in for a £5.
