172 Running Gear On Non Sport - Questions..
Car  R5 GTT EFI Clio.
I want to use 172 front and back brakes on my ph2mk2 clio, its a 1.2, as many of you know i have intentions of putting the F7P turbo engine into it when the car is ready. Shouldn't be to hard of a job because i will be removing the ABS, and running a 172 cup master cylinder straight to the calipers.
What i want to know is what parts do i need to souce?
Was talking to Rob, and he said he is pretty sure i need a fully complete rear beam? just wondering what does this need to include all together? im guessing, Rear beam, Hubs, Disks, Calipers? Anything else that should be included on the rear beam?
What do i need to change on the front?, i want it to have the same shape as the sport, so will be doing front and back bumpers, sills, wings and turini's etc, but for the running gear, can someone just help me make a list please?
cheers.
As far as the rear goes, I'm changing my drums to disks after getting the 182 conversion.
I've got a Trophy rear beam (calipers and discs came with it) although I've been told by Ktec to get mk1 rear discs so that the ABS will still function.
There are always sport rear beams on ebay and I got mine for a good price...
Here's one on there atm...
http://cgi.ebay.co.uk/Renault-Clio-...arts_Vehicles_CarParts_SM&hash=item439f6e0c5e
As for the front - Ktec sorted all that for me so I didn't have to worry. Good luck with the conversion.
Thanks Vicky x
I will be removing the ABS, so im not bothered with mk1 rear disks, will go for straight 172 gear.
Thanks again.
Can anyone help with what stuff il need for the front?
Cheers!
The list is rather extensive.
It'd be easier just buying a ph1 and swapping everything over tbh. Probably cheaper and certainly quicker too.
You wouldn't have the wider cup gear though obviously.
front end you need
subframe (others will argue but you need it.)
wishbones
hubs
struts
brakes
ARB
Driveshafts
standard steering rach has more than enough ajustment to correct tracking :D
Thanks a bunch hutchie! - What is ARB?
Im sure i can pick most of this up from the scrappy, any bearings and bushes will be replaced, but should be ok.
bearings and bushes. tbh leave standard alone, if it aint broke dont fix. once they been apart they never as good IMO
ohh brake hoses are a different length, but i got away with standard ones for months. its only on the lift that its a problem as when car is sat level it is a shorter route anyway :D
Well, i will be stripping all current break lines and replacing them, will be stripping ABS out, and using a 172 cup master cylinder, and then using braided lines from the unions to the calipers i guess.
Dont happen to know the origional renault break line outter diameter do you? as the stuff i got here is 8mm o.d 0.6mm thick and i got 20 meters of it (2 packs) just wondering if its going to fit into the master cylinder?
front end you need
wishbones
hubs
struts
brakes
ARB
Driveshafts
subframe isnt needed . mine is the standard dci one and everything fit fine . and you also need the little bracket that bolts at the back of the engine to support the drivers side shaft
that depends on what the rest of the kit you have is. you only need that to go with ph2 172 non cup, or 182. A ph1 or a 172 cup doesn't have a center bearing
ahh i see , was a right pain in the arse tryin gto get hold of one in the end my made just fabricated a bracket .
not that expensive from renault IIRC
You have to get hubs and driveshafts from matching cars, as the shafts are different lengths. I've put 182 shafts (with center bearing) on a 172cup as an upgrade though.
Thanks Champ, you said you used your dci subframe, is that going to be the same as mine? if so, how did you find the fitment of the wishbones and other stuff, is it a straight fit?
If so, il use my subframe as they aint the cheapest of things.
thought so.. might have a few questions for you to il drop you a pm
yeah itr all fits asif you were fiting it onto a sport again . arb is diff but you only need to drill a hole to bolt it to the subframe or thats all i needed to do in my case .
need to know anymore drop me a pm mate
