172 starting problems, help!
  RenaultSport clio 172 mk1
my mk1 w reg 172 is having intermittant starting trouble as in sometimes it starts up first time others it takes maybe 5 tries. If i unlock the doors with the keyfob sometimes the red round light in the main dash between the rpm and mph clocks flashes and it wont start.
If i relock then unlock the car it may start then as the light is constant red.
Its not a battery as thats been tested and i've checked for loose connections, i'm certain its not starter motor or ignition. which leads me to think immobiliser problem. (also the trip computer is resetting itself when it wont start)
Any ideas or starting points for investigation much appreciated.
Mine does this too, only occasionaly though. I just relock/alarm it and then off again. Always starts first time after that, not sure where you would start though.
^^yeah heard people talking about that on hear but wasnt sure if its related, will give it a go in morning and report back, thanks
