I have just last week had the same problem, the car would start intermittently, sometimes it would start 1st time, I would drive 2 miles stop then take 5 mins to start, other times it would take 2 - 5 mins to start. I also have the problem with the Serv, ESP and ABS lights coming on whilst trying to turn the engine over, I normally turn the key so the dashboard lights up, put on the seat belt then when the immob light has gone out start the car but I have noticed that although the above lights have gone out they light up when I start the car, Do you have the same prob or has anyone else noticed these particular lights comming on.cjay said:Iv'e got two keys and I have the same problems with both. If it is an immobiliser problem will a new key solve the starting issues?
Check with your mechanic, could be the TDC.cjay said:I've got a problem starting my 02 172. When I turn the key the engine turns ok but doeson't start as if it is out of petrol. I've tested the petrol pump which is fine. Could be an immobiliser problem? Any suggestions?
