172 Suspension Torque Wrench Settings
Car  DCI100 / 211hp MK1
Afternoon All,
Just wondering if anyone has the torque wrench settings for assembly all fo the suspension components back together and then fixing them back on to the car.
Im talking about things like.
Brake caliper to carrier
Caliper to hub
Ball Joint to wishbone
Wishbone to Subframe
ARB mount to wishbone
ARB mount to subframe
Steering rack to subframe
Lower balljoint pinch bolt
Suspension leg to hub
Subframe to car
Rear beam to car
Rear beam to mounts
Rear beam stub axle assembly
Brake disc and bearing to rear beam
rear caliper to rear beam
May have missed a few but you get the idea,
Please no sarcy comments like FT etc.
I know roughly how much to do them by hand but i want to do exact measurements if possible
Thanks peeps.
Balljoint to wishbones 30nm
Wishbone to subframes 80nm
Pinch bolts 20nm
Arb to wishbones 20nm
Caliper bolts are 30nm iirc
Caliper to carrier just needs snug and a bit more ;)
A lot of bolts its a case of use your noggin as to how tight they need to be
TBH with there being no haynes manual to give torque setting ill just base them on the old mk1 clio i had but thanks for the ones so far.
lol that is what i done tonight as i had to start assembling something rather than painting its so god damn boring!
