172 - Why is my car's idle crap
Sib
Car  Clio 172 (Silver)
My car runs sweet as a nut, no lack of responce anywhere and has no apparant issues.
However, after about 1 min it starts to idle like a bag of bolts on a bouncy castle.
Is this normal, are is it service time?
Mine is a bit like that too, think its a normal thing. To do with the valve timing.
There is nothing wrong, when the engine is cold it will idle slightly higher than warm as it runs a slightly richer fuel mix to get the engine up to optimum temp.
If you think its that bad then compare it to another Renault Sport Clio.
my old Mk1 172 used to hate 95 RON, it ran like a bag of shoite when cold.
i've not tried 95 in the 182 yet though, i doubt i ever will
Having exact same problem with my 182. It was suggested to me that I use Slick 50 Fuel Treatment and put a full tank of BP Ultimate or Shell Optimax in after adding the Slick 50. Only just got the car and have filled it up once (with standard BP Unleaded) so next time I need to fill up I'll give it a try and let you know.
