i got the pedals from reanult, just the silver bits and had to rivit them onto the ones in my dynamique, so i rivited a metal pedal onto the plastic accelerator pedal so i think they are is different. but i have no idea in terms of resistance
right, sisters 1.2 16v is driving like s**t, wont accelerate and coem sup with the fault of accelerator pedal potentiometer
ive got a 1.2 16v courtesy car.. if i borrow that acclerator pedal and plug it into my sisters car.. if thats the problem fixed, should it run fine? or does the ECU need resetting by the clip machine to clear the code for it to run ok??
I'm sure there the same the resistance values from the potentiameters is the same.
However there two potentiomerters in the pedal if one fails then the other works and the ecu deteckts the failure and ups the rpm to 1.3k or so and sets the warning light off so I'd not think it was the pedal.
