182 4 point harness mount locations
4 points aren’t ideal at all
Neither is bolting them that low down
I’d take the guys advice and avoid this until you can afford a cage really ?
This isn't my forte so I’m not giving you my expert knowledge
But when I fitted my harness I was strongly warned off them
Research 4 point submarining.
Basically where the harness are tight and have no pre twnsioners the momentum has to go somewhere
It pushes you down into the seat and can cause you spinal compression ( I think it was)
But research it
I went 6 point after that
I've seen a few people using the rear seat belt locations for the top ones so I think that will do until we get a bar.
Where would we mount the 1/2 lower ones on a 5/6 point harness?
Ol’ Tarby
  Clio 220 Trophy
I *think* the rear seat belt points are ok aslong as the angle of the harness is less than 45 degrees? Something like that anyway.
Just because someone else has done something, doesn't make it ok. Research into the correct way to do it. Going head on into a barrier/tyre wall even at relatively low speeds is gonna cause some issues
If you just want to be held better, then look into a CG lock for the standard belt
Darren61
I can’t understand the gamble that is taken with stuff like this.
If there’s one thing worth doing properly, above anything else, it’s the stuff that keeps you safe.
And I know there’s always an inherent risk with “Motorsport” but come on...
Brakes
Tyres
Harnesses/Cage
Spend the money on these before you spend money on go faster bits
green
  Hi comp phase 1
This is my old shell with a harness bar welded in...only pic I could find after I wrote it off:cry:.
When I got the seats and harness I thought using the existing seat belt points was a bad idea so I got a roll cage company local to me to do it....it served me well for a few years...even when I crashed!
Since then my new shell got a proper(bolt in) cage and they are well worth it..not just for the harness bar but a stiffer shell.
I did wait for a second hand one to come up for sale. I just had to get the weld in towers from Safety devices.
The cg lock is a good shout
And I think you’re right about the 45 angle just wish there was a yes or no to the info
So much info but no idea what’s fact or opinion
I think 0-10 degree is deemed best and I thinknits in case of you rolling the car
But it’s very important hence why I’d go all or nothing personally
Brakes
Tyres
Harnesses/Cage
100%
