182 ABS light?
Car  Turbo Beige
I fitted a new steering wheel to the car a few weeks ago and got the usual lights etc. Couple of days later the ABS light came on and is still there, i have checked the fuse and that is fine.
Any ideas as to why it might be on?
is the esp light on aswell or just abs? is the light on after 3 secs of turning the ignition on or only when the car goes above 7mph?
Light is on all the time, i also have service, airbag and esp lights on. I know why the others are on. Know idea why the abs is on.
the only thing as youve been in that area would be steering wheel angle sensor but what the fault would be i do not know without putting a diagnostic on it.....other wise it is just a fluke that the abs/esp light is on and the computer is picking up a circuit fault.
Ive had the same problem with my Trophy. The Airbag light, SERV light, ESP light came on the dash when i changed my steering wheel for a Momo. I put 2 x 3.3 ohm resistor in the air bag green and orange connections that fit to the airbag on the standard steering wheel, this took the Airbag light out.
2 days lata the ABS Dash light was also illuminated permantently from starting the car it was always on, this is apparently because the cruise control has been disconnected and the cruise control uses the cars brakes to keep the car at one speed. Ie if you set the cruise at 70mph the car will sit at 70 mph on the flat but accelerate up a hill to keep it at 70 mph. Therefore it will also brake the car when going down a hill to keep it at 70mph and not let it go over 70mph.
This is why the brake ABS light is on my dash it dosent mean there is a fault or problems with the ABS it is just illuminating this light as it notices a fault as it now has a broken circuit as the Cruise Control has been disconnected.
Just to prove this i reinstalled the standard steering wheel and all dash light went out when all connectors were plugged back in to where they were sopost to be.
Hy,
I got a clio182TEAM,fitted OMP corsica steering wheel,ABS light is ON always when i start my car,but if you turn off the contact (while driving) and turn the contact immediately after that ON,the light disappears,and your ABS does work!!!
Try that
Hy,
Try that
What do you mean by the contact?
My light is on and the ABS isn't working!!!
PYE21, i got the exact same problem and happened the exact same way, ABS light didnt come on for a few days.
I was heading towards a roundabout, fast, when mine cut out, which made the front left lock up badly! was exciting to say the least!
Turn off the CONTACT,does mean,turn your KEY,so as you would turn off yourcar,after that you turn it on once again(while driving)
yes?
So your ABS will work
