182 air con confusion
Car  182 cup
hey
after finally getting the hang of the cruise control ive now turned to the last gadget the air con
now it may sound strange but i cant seem to turn it on
tryed the search thing on here but cant find an answer
i assume when the orange light under the A/C is on the air con is on?
or is that wrong?
ive tried turning the fans on full and temp to the lowest (min)
but it feels no different if the a/c is pressed (orange light) or depressed
is there any guide on here or can anyone give me a quick lesson on how to use it before the hot weather gets here
the cars on 15k miles btw and all the fans work fine
cheers
click the auto button....that turns it on..
the other buttons regulate the temp, you will see it on the wee screen...and the last button re-circulates the air...keep that off if your feet stink...
just read your edit..
sounds link it mite need recharged or somthing if the temp doesnt change...mine goes ice cold when its on minimum...
what is the age of your car..?
when i click auto it sets the fan level to medium and turns the orange light on the air con on
will the aircon work at any fan speed?
and does the temp have to be on (min) for the aircon to work?
its a 04 plate with 15k on clock
just dont notice any change whether the light next to a/c is illuminated or not :S
also on my GTI-R if you turn aircon on the revs drop ever so slightly as they would if you turn on stereo or high beam etc
on the clio there is no change at all ...? made me question whether it works at all or is that just what new cars do :cool:
newest car ive had before this 182 was a X reg subaru p1 so as you can probably tell all these gadgets confuse me
jesus ...i sound like an old man and im only 25!
depends on the temperature in the car! the fan speed is proportional to the temperature. It runs a closed loop system and if the setpoint is 20 deg C and the car 20 deg C inside it will maintain it at that temp with a low fan speed. If you was to open the window with a outside temp of 25 it will ramp fan up to try bring the temp back down (odviously it wont be able to so shut the window!)
right so maybe thats cause i like being cold all the time
i never wear a coat even in winter
maybe its works just not very well?
so i'll just keep temp on min all time unless im demisting windscreen and "auto" turns aircon on to achieve "min" tempreture
and the orange light "on" on the aircon button means that the aircon is "on"
sorted cheers lads!:cool:
sounds like the gas needs changing to me. When a/c on its freezing cold, if it isnt then you need refilling
