182 alloys on a mk2ph2 tyre size???
Car  clio 5door sport rep
Hi guys
As above looking to know the cOrrect tyre size for 182 alloys on my mk2 ph2 non sport clio, so that my speedo isn't out and no rubbing or anything cheers
If you go with 195/45/16, the overall diameter is pretty much the same as your standard fit. There is like 5mm difference, so f**k all really.
yeh bt u dont wna go over 195 or as soon as u get a couple people in the back it'll chaffe
they might be ok, it's just the rear arches are rolled slightly on the 182, so you may get scrubbing when there is more weight in the back.
hmmm got a five door.... usually do have some folk in the back... dont think ill risk it in that case :-( raging
will the wheel not wobble at high speed with universal spacers tho? have my daughter in the back has to be safe cheers
