182 battery problem!
Car  Fiesta ST
If I don't use my car for over 2 days the battery is dead and car won't start! Happens everytime its ok if I leave it for 2 days or less. When I drive for about 20-30mins after getting a jump start its all fine again unless of course I leave it longer than 2 days.
I pursume the alternator is fine because it's being charged when I drive.
Can it be a faulty battery? I can't see anything that could be draining the battery?
any help and thoughts would be great!
Sounds like it could be the battery. They loose there charge if not used. My escort did this after a day lol.
it's probably your battery. I had this prob on my last car. except it wouldnt start ever when turned off. Bought new battery and all was good.
Check for a power drain the rear boot light can drain the power if the switch fails.
Get the battery checked though.
sorry for the old bump but I got a new battery and its draining after a few days. :( something must be draining it. How do I locate it? as mentioned above check boot light and glove box but what am i looking for? if the lights staying on or what?
Any help would be great!
Guess so yes, press the switch in as if the thing is closed and see if the light stays on.
Check the light isn't stayoing on when the boots closed etc.
