hi, if you can find it in the UK, front caliper from citroen BX are a perfect fit..... mono piston in 54mm if i recon perfectly and they are equipe with a similar handbrake system , wich allow you to keep you handbreak working...
yes but if you put big brake in the front you have to adjust you ratio front/rear or install big brake at the rear... otherwise you wont use the threshold of your brake anymore.
