182 'Cup' Front ARB
Car  RS172 Flamer
I have been reading into the 182 Cup/Trophy/FF and apparently they have a thicker anti roll bar than other models. My question is: Does anyone know if this would fit on the other models? A 172 Cup more specifically...
Surely though that extra 2mm would help, I would of thought. I know, for instance, that Whiteline do thicker Anti Roll Bars for Subarus and Audi Quattros etc as handling uprgade option
Iirc its only 2mm so pointless imo
2mm extra in both directions (ARB = round) makes quite a difference.
I thought they were all 25mm though on the sports TBH?
Assuming you are right that they are 2mm bigger, I would imagine that translates to something like 20% stiffer?
182 Cup and 172 Cup both have the thicker ARB.
Clio Ph1 2.0 16v RS-172: Outer mount - 22mm, Inner mount - 25mm
Clio Ph2 2.0 16v RS-172: Outer mount - 23mm, Inner mount - 25mm
Clio Ph2 2.0 16v RS-182: Outer mount - 22mm, Inner mount - 25mm
Clio 2.0 16v RS (172 & 182) Cup / Cup pack models: Outer mount - 23mm, Inner mount - 25mm
The inner are all 25 but the outer are different.
Many thanks for this! At least I know what size Poly bushes I would need :)
And thank you to the others for responding also
