Register a free account today to become a member! Once signed in, you'll be able to participate on this site by adding your own topics and posts, as well as connect with other members through your own private inbox!
Bin that rack & fit the dci 1 as it's better but you will need a Valver power steering column as well.
Then it's just a case of fitting the appropriate track rods & ends
OK thanks mate, any idea which inner track rods? At the moment my options are the ones that are on this manual rack or the ones on the dci rack. Which models had the power steering column too? Not finding any columns on ebay will try facebook.
I fitted the ph1 Valver/Williams ones to my dci rack but because of the Bridgecraft bits you've got it'll depend on what the measurements are to determine which inners you'd need
Found a column I'll collect in next few days, looks to have two connectors though I was hoping I could just plug in power and it would work? Are these just for the ignition? Also which bits need welding/strengthening on these?
I run it as is, just as a manual rack basically.
The reason for the pas column is that they're shorter than the manual column so it's just for fitment that it's needed
