i recently replaced my front shock that was 56 quid (got charged 40 quid for the labour) i only found out it was knackered by havin a spring kit fitted.
Other than the bolt spacing whats the difference between the 182 cup and standard 182 shocks?
my local factors say 54 each shock. I need them for mine
What you mean by bolt spacing ?
My rear nearside shock absorber on my 2004 182 cup is buggered, out of curiousity does anyone know the cost of a replacement?
Cheers Jason
A pool of hydraulic oil over the drive way is a good sign. My shocker had incontinence.
bolt spacing on the hub is different. 54mm and 58mm or something like that CBA to search lol but you get the idea
Forget spax there rubish particularly the rearshttp://www.demon-tweeks.co.uk/products/ProductDetail.asp?cls=ROAD&pcode=SPXG3247&app=Y
These are top adjustable ones from Spax (ok not the best make but the renault ones leak like leda's lol). Will these fit the 182 with cup pack tho? Mention 60mm spacing but only on the front!?!
different setup 54mm none cuped to 60mm cuped specOther than the bolt spacing whats the difference between the 182 cup and standard 182 shocks?
