182 Cup Suspension
Car  RenaultSport clio 182 CUP
As i already have a Original 182 Cup what good suspension set up would you recomend for fast road and the odd track day;)
Leda but there £900 they are superb setup though.
There not much chocie the Gaz ones are a bit hard but cheaper at £500 or so, and there the Blistein/YozzaSport ones for £1.3k.
BLUNTY said:
But all these are coilovers what about changing the springs
Yep any 172 springs setup will fit.
There a load of choice the eisbech sport lines are quite good I belive.
But the 182 cup set up is diffrent to a 182 its lower so are the springs diffrent or dampers
Yes and no unfortuanlty
Any 172 spring kits will fit.
The front shock hub spacing is the old difference fitting wise for the 182.
So eibach springs will these lower my set up by much and will i need to re- aline my wheels after fitting
Yep you'll probably need them realighning or best getting it checked.
I think they lower by about 20~30mm.
