182 ecu bracket!
has it snapped off from the little bit near the strut top?
if so all i did was got a little piece of metal and drilled through it and the existing part of the bracket and bolted it all together. ghetto style FTW
drilled a hole either side of the break, got another strip of metal and drilled two holes in it, washers, nuts, bolts = done
20 mins job. I had a knock on start up and sometimes over uneven ground - it was this bloody thing
doubt the grinding/vibration is from it mate, may have something else wrong too.
Best to fix the bracket then go from there
