182 engine hesitation / rough running
Car  clio 182
Hi, searched the threads, found similar problems bt not the same, engine idles fine, will rev fine but once on the move engine seems choked, more throttle makes it worse, take my foot off the throttle and will idle fine. Any ideas?
I had this problem it , it might be your crankshaft sensor look At ,y post on the faults section it had similar problems to you but was v.ery intimatent
