182 exhaust mounts.
Car  DCi
I have changed my exhaust recently and the 'spider' mounts at the back are perishing a little.. so I stuffed them up with garden hose but it's still a little bit lower than I would like
Would it be sufficient to replace the mounts directly from renault (anyone know an approx. cost?)
Or does anyone know of uprated (harder?) rubber mounts for the 2 back mounts of the 182 cat back?
cheers...
Have you got the standard Renault exhaust?? From experience, hardening the standard mounts halves the life of the exhaust.
I also recommend the CES sourced mounts. Fitted two a couple of weeks ago. Exhaust sits well for the moment. It's just a shame the parts were not designed adequately in the first instance.
Check out this item number on ebay- might be what you are after.
130262848482
looks good I will compare with CES and make my choice :cool:
try these guys:
http://www.cesuk.com/index.php
i order two from them a few months ago, cost me 6.55 each delivered the next day, renault wanted something like 20 odd quid each
thank you kind sir :cool:
Just use cable tie's, job done.
already doing that to 'help' the low hanging exhaust problem but it's still too low, idealy want proper parts!
nope I have a milltek, out of curiosity what happens/how come?
thanks people!
