Hi all, I just wanted to reach out for some advice. I've had my 182 for 1.5 years now (second 182). It's unmodified except for exhaust, hasn't been chipped. I keep getting an issue where it runs EXTREMELY rough for about 2 minutes upon starting, and then runs perfectly, it just happens the first time you start the engine on a given day. Only time recently it did not do this was the 37-40deg days we had. I know some people say they all do that, but I'm talking you can only apply max 5% throttle otherwise it lurches and backfires, so it's a struggle to get up to 20/30mph. Mark Fish and Two Techs have both given it a look over. This issue happened from when I got the car, but then for 6 months after replacing the battery it was totally fine (and only slightly rough on starting like my old 182), but just spontaneously started happening again recently. No codes are showing up at the moment. I ran it with a home OBD2 scanner and noticed the lumpy/rough engine is timed with spikes/dropouts in voltage so I wonder if it's something electrical? It's throwing no codes at the moment. I've had the following relevant bits replaced new in the last year (but a lot more aside).
New injectors (code)
New spark plugs
New battery
Cambelt/Dephaser/AUX belt
Water temperature sensor & connector (code)
Oil/coolant
Exhaust mounting fixed and re-sealed
Possibly from reading/discussing with mechanics it could be the crank angle sensor but I wondered if others had any other ideas before I just throw more of the parts bin at it? I recall reading there was a sensor which is just used for the first 2 mins for oil/air ratio whilst the engine is heating up and then it switches to another, but I can't recall now whether that's the crank angle or another sensor? Any advice would be appreciated!
Cheers,
Nick
New spark plugs
New battery
Oil/coolant
Cheers,
Nick
