182 Head on 172 Cup Block
Car  172 Cup & K20 Ph1
Hi All,
I've searched the forum but couldn't get 100% clarification... will a 182 cylinder head fit directly onto my 172 cup block? I'm looking at purchasing one and having it ported, polished, new valves, new valve springs etc, but don't want to do all this work to find out that I'd need a 182 block also.
Many thanks
Rhys
Wow, is that right? That's interesting... I'm seriously torn between tuning N/A or going turbo instead!
Itb's are well nice :) the sound is just pure sex. Tuning potential is not great tho (bang buck etc)
I'd also like to elaborate on what I just said......
Boosted for same price for more power on standard internals.
It would cost 6k to reach a low pressure standard. From start to finish
Oh and the itbs are prone to having to be balanced every now and then.
Hear someone say on here it's better to blow than to suck.
Read t.trophy (Stevens) threads. Search turbo.
Chip wrote this;
Originally Posted by M6 TMW
For a genuinely quick car yes it's much cheaper. No denying that.
My Fiesta with n/a zetec and a short gearbox felt fast enough with 814kg including me as driver and a full tank of fuel and the interior. That was 195bhp and 150lbft. With the Clio the same figures won't feel very quick, it's got another 300kg on top. Boost required!
I tend to think of roughly (include weight of driver / passenger):
150bhp per tonne = ok for getting started on trackdays, but you'll get stuck behind people a lot and frustrated if your car handles well so you catch them in the bends but then cant get past them on the straights and arent allowed to overtake them on the bends
(e.g Standard 172)
At this level on medium speed bends after a short straight you may find your car is so slow you cant enjoy the corner as the car cant accelerate to the speed you need to in order for it to feel like a corner
175bhp per tonne = At least you can pass most normal cars just about on a long straight, but still pretty hard work
(e.g throttle bodies 172 or RS2 and a set of 197 cams, hot cams on standard inlet just about)
At this level on high speed bends after a short straight you may find your car is so slow you cant enjoy the corner as the car cant accelerate to the speed you need to in order for it to feel like a corner
200bhp per tonne = Will pass most normal cars relatively easy on the straights so little chance of ending up too stuck behind someone too often
(e.g as above but stripped right out, or bodies plus cams, or low pressure turbo)
At this level on very high speed bends after a short straight you may find your car is so slow you cant enjoy the corner as the car cant accelerate to the speed you need to in order for it to feel like a corner
250bhp per tonne = Starting to actually be a fast car, should be able to get past M3's and the like
(e.g low pressure turbo and stripped, or mega lightweight cars with bodies and cams like the burspeed, or a high pressure turbo)
At this level I cant think of any bends on uk tracks you wont have enough power to really exploit your cars handling by getting upto the max speed it can go through them at.
More than that = TBH the extra pace now only really helps in the middle of long straights as you cant really use it coming out of corners very well anymore and as per above its not really needed to get you upto speed on the way into bends either.
Ideal if you want to race people down dual carriageways etc, but in a FWD hatch on track its not really any advantage over the 250bhp or so mark really.
If you do want to go for something like 300bhp per tonne, I would do it by having 300bhp and stripping the car, rather than having 400bhp and having to have huge brakes etc
The direction I'm going is as light as possible, i.e. totally stripped, custom loom, custom dash, lightweight battery, polycarbs all round, fibreglass bonnet/tailgate/doors and then 210-220bhp under the hood.
I'm no race car driver and the car won't be in any races, but I want to have some real fun in it, have a hobby to work on and really enjoy it as much as I can!
If you can get the weight right down and make that sort of power it should be very capable on track.
