182 Immobiliser / Battery problems... Please help!!!!
Car  L'arctic Bleu Clio 182FF
Hi all,
Had a nightmare today, took the Mrs to do her race for life charity run, left the car for about an hour and when we went to leave, the car was dead.:dead: (So much for doing a good deed!? :rolleyes:)
The car is a 54 reg (Jan 2005) 182, 29k miles (had from new).
We have had no previous problems with the battery etc.
Basically, when we turned the key, all the warning lights would stay on, and nothing would happen. The radio wouldn't work, the remote central locking wouldn't work, just complete and utter non-response.
Got a guy to give us a jump-lead boost, and nearly had a bit more action in the engine, but still nothing, i.e. it wouldn't get anywhere near to starting.
The RAC came out and charged the battery (he said it was dropping to around 6 volts when we tried to start it), and the engine almost kicked into action a couple of times, but he couldn't get it started - even after disconnecting everything from the battery, and checking the electrics underneath etc.
He said that although the battery is probably going to have to be replaced (anyone know what they cost for a factory fitted replacement??) the immobiliser also has a problem as the red immobiliser light is flashing once you turn the ignition. He also said that having jump leads fitted before he got there may have damaged the immobiliser as the electrics in it can be very sensitive! :mad:
I have a local guy coming to do some diagnostics on it tomorrow morning (charges £35 to find what the problem is) but he said the liklihood is that it will need to be sent back to Renault because the factory fitted immobilisers are a nightmare to work around. So looks like I am going to be seriously economically violated on that one too!
So, in summary after this epic essay!...;)
- Has anyone had a similar problem before?
- How much is a new battery likely to cost?
- What are the charges likely to be at Renault? i.e. getting the car there, labour, resolution etc??
Thanks for reading/replies guys, really appreciate it!:)
Cheers,
Martin.
What i would suggest is getting a new battery, and fitting it. Leave the battery disconnected for around 10 mins when changing it. And go from there! It may fix your imobiliser problem.
Had same problem that turned out to be a break in the battery cells so the ECU was only receiving 6-8 volts. New battery and no probs since.
Battery swapped, started 1st time!!!
Just goes to show, RAC man said that we definitely had an immobiliser problem, so if it wasn't on a Sunday, I probably would have taken it straight to Renault to get looked at, and doubt that would have been cheap!
Guess a battery replacement and a decent period of disconnection is always worth a try!
this happened to me, flat battery so rac man changed it and it was immobilised.. so i had to leave it unlocked because it wouldn't and he said it will need to be taken to renault to be reset, so next day another rac man comes to tow it and gets it working by just turning ignition key on for 20secs before starting.. pfft.
I'm new to the DIY car fixing, but i'm quickly learning that it pays to have a bit of savvy and try and investigate things for yourself before you head straight to the higher power that is the main dealer! ;-)
