182 Laser Tracking results....Guru needed
  182
Right had the tracking done by ELITE the other day on my 182 and here are the finished results,
The front which is adjustable camber, castor and toe has now measured up well but the rear is not, here are the results of the rear only;
Left Rear Rear Right Rear
-1.40 Camber 0.20 Total Toe -1.37 Camber
0.12 Toe 0.02 Thrust Angle 0.08 Toe
Alot of people including myself wont/dont understand those measurements, but the printout that Elite gave to me also shows these colours. Basically the more green there is the better it is. Black represents a measurement that could not be read clearly or something like that.
The whole front measurements are all green because they are adjustable.
Because the rear is non adjustable do you think that the measurements should be spot on?
Could these measurements ever be spot on anyway when the car was made?
Is there anything that could be causing the rear to be out like that ie mechanical, suspension components etc, admitably its not alot but it is still out??
Should the car go back to renault to investigate the matter further?
Comments and advice please
Rob.
[Edited by rwaterman on 04 March 2005 at 2:11pm]
  Embarrassed to say
How much was the front out. Its not like your dealing with an OPC, Renault will probably say its within its acceptable tolerance for error or something.
  182
The front mesurements before it was carried out;
Left Front Front Right Front
-0.38 Camber -0.17 Total toe -0.38 Camber
2.27 castor -0.18 Steer Ahead 2.41 Castor
-0.26 Toe 0.09 Toe
Now all the front are in the green,
Cupsportmad i wondered whether or not that there would be an acceptable tollerance level to things like this. Anyone else had similar..............
Whats OPC?
[Edited by rwaterman on 04 March 2005 at 2:26pm]
  Embarrassed to say
The vx220s are way out and you cant get them soughted on warranty, most owners goto scared stiff in daventry to get them done. My mate got his porsches geo soughted by his opc, thats why i mentioned it.
