182 Manifold Fitting - Ball Joints
Car  RS Clio 172 Cup
Hi guys,
I'm going to attempt to change the manifold on my 172 for a 182 spec one over the next few days, I've looked over the guide (http://www.cliosport.net/forum/showthread.php?313845-182-manifold-coversion-on-172 , which by the way is awesome!) and it looks alright except the bit about the ball joints. I'm not really sure how to remove these, is it a difficult job? Will I have to get the alignment done after? Any advice much appreciated!
how much did you pay for the manifold, if you dont mind me asking. i want to decat mine, and fitting the 182 manifold would simplify things. thing is they cost £150+
I paid £175 delivered for mine (about 40k miles) from a Clio breaker guy when I was buying a few other bits. The decat itself if pretty expensive from Ktec, I got one second hand off here for £60 which is pretty good. The only problem is you then don't have a cat for MOT time, and changing the manifold is a pretty big job!
that's the reason i want the 182 manifold- changing a cat and decat on a 182 is much simpler than the 172, but of course it means buying a 182 manifold, a 182 cat and a 182 decat. although i wouldn't have to buy the cat until next year which takes some of the cost burden away.
i want to get matched inlets and stuff but it seems fruitless without a decat.
I'm afraid you seem to be missing the problem here - a 182 manifold and cat (or normal 182 decat) will NOT meet up to a 172 exhaust system. You need a special decat or sports cat to fit them together, as far as I know Ktec are the only ones to make these. The 182 mid section does not finish at the same place as a 172 one. Hence the problem with MOT time, you either need a special sports cat, modified 182 one or a friendly MOT tester!
;) that's why i asked yesterday if you had a 182 exhaust or 182-to-172 cat/decat
but then i forgot about it in my last post :S
so it's 182 manifold and decat and cat of sorts.
the more i write about how much stuff is needed the more i think just fit a 172 decat and try my luck come mot time
Yeah basically all you need is a 182 manifold, special link pipe or sports cat and you're done! I have seen people who have modified a 182 cat to work as well but better of talking to a custom exhaust place for that, likely to be much cheaper than a sports cat though!
I had a few other problems so decided to bail on the whole 182 manifold idea to free up a bit of money, just did a decat with 172 mani. And no emissions light yet either!
