182 problem
  ///M135i
hi, just new to the forum!
bought my 182 a month ago 40k on the clock FSH. when I start the car cold (starts no bother) i pull away change into 2nd and there is a banging from under the car. also the car pops out of 1st sitting at lights. the clutch also seems heavy and stiff. could this be the dogbone mount?
cheers! michael
check the exhaust heat shields for the banging...corrosion can cause them to come loose!
P.S. the clutch is heavy anyway cos its a 2 litre!
cheers mate.
another question, i leave the car at work at 8am come back at 4pm to pick in up and it starts but the revs take a dive and the car judders. any ideas?
michael
The clutch is relatively stiff yes, but it has nothing to do with the fact its a 2 litre!
Aye I'd take a look at heat shields on rear back box as Budgie said mine was doing this a few months back especially round bumpy corners going slow which made me think something was loose and turned out it had rusted just round the washer, bigger washer and problem sorted hoe it's that simple for you!
Clutch took some getting used to when I got mine especially in slow moving traffic felt like my leg was going to fall off from lactic acid build up lol don't notice it after a year though until you get in someone else's car then back in your own. It's that wierd feeling like when you used to swap bikes with your mate when you were little
DoH..
cheers mate.
michael
You could try cleaning the throttle body, although they are all crap on cold starts mine included and my TB is now shining :rasp:
PM me if you want to try it and I'll help you out, isn't really very hard.
