182 Rear caliper slider pins
  Clio Trophy
Struggling to find these listed anywhere, can anyone point me in the right direction?
Front ones are no issue to find but I'm told the pins in the rear of mine are worn.
To the point the rear brakes can make a bit of a racket if you pulse the pedal when coming to a standstill.
MarcB
  182 Trophy & 197 F1
As said mate its item number 4 on that image that looks like the sliding pins and rubber seals.
R/KIT CALLIPER
77 01 201 837 - RRP £51 +Vat (Each)
  dan's cast offs.
might be a bit corroded but it's normally the calliper that oxidises and that pushes the rubbers against the pins and stops the calliper moving.
