182 STD Exhaust removal
Car  Clio 182 Trophy no. 235
I took a look at it earlier and it runs above the rear axel, how has anyone managed to remove the std exhaust? is cutting it the only option, or could the rear axel be repositioned to accomodate?
Any help would be much appreciated thanks
you need to cut it. reno fit the exhaust, then the back axle. if you cut it i think just before the axle, thats where the new one has a join. so you can mate it up. unless youre replacing the full system in which case it doesnt matter where you cut it, just rip it off!!
You can drop the rear axle (Andy GDI has done it) but easiest way is to cut it just before the Y piece.
yeah, i should add its best to wait till youve got the new peice to see where to cut it, saves gettin out the mig
