182 stereo help urgently required!
NickTTRS
  Audi TTRS
I have just pulled out my 182s head unit and replaced it with my Alpine unit. As the Alpine was fitted in my 172 it already had the correct connecters on it so i have not cut any wires at all and when i switched it on worked okay. Now the problem is that the digital clock on the top display has to be set every time the ignition is switched on and there is some weird clicking noise coming from behind the speedo. Okay i thought to myself maybe the connections are wrong so i put the 182 stereo back in only to find that it wants the radio code every time i turn the ignition on. So now i have the clock wanting the time, the radio wanting the code and this peculier noise from behind the dash! If anyone has any stereo/electrical advice on this problem i would be very interested to hear it as i only touched the wiring to the head unit! Thanks!
KDF
  Audi TT Stronic
Quote: Originally posted by Chad on 18 May 2004
Might have blown the fuse to the permanent live
My thoughts exactly.
Tom
  i3
I did the exact same thing to my 182
i blew up the alarm
check the fuses.
(tho i kept it quiet cos its embarrasing)
NickTTRS
  Audi TTRS
Cheers guys it was the fuse! I thought i had done something serious then. Phew! I dont know how i did that though, my Alpine was working okay when i put it in (not that i will try again however).
  Ford Fiesta
wount display on the dash screen will it if you change headunit, does your temp still show though? what about remote control?
KDF
  Audi TT Stronic
You will retain the Temp and clock, some makes of HU have adapters so you can retain the sattelite controls + limited display..
  Scenic mk1 (F3R)
yea if u want the lot you gotta invest about £30 in an adaptor for all display and controll
