182 throttle open after spark plug change
Car  clio 182 ff
hi
just changed the plugs on my clio 182 using ngk pfr6e-10
now when i start the car it rev's immediately on what appears to be full throttle
any help would be greatly appreciated
as i have just posted in your first thread, if you removed the inlet manifold to change the plugs, its worth removing the manifold again and checking the seal on the underside is sealing ok, this could cause it to run as if its full throttle
