Kiev85 Dec 23, 2006 #1 hey just had my drivers side top strut replaced... it turns at the thread by hand? is this meant to do it? the other older one does not turn at all..
fUbAr Dec 23, 2006 #2 we talking about the top strut mount? no, its not supposed to turn, however it will have a bit of play in it as its surrounded in rubber.
Kiev85 Dec 23, 2006 #3 it is loose...i can turn it a fair bit....dont want to tighten it or anything, as im assuming both sides have to be the same.. the bit that has the thread stickn out..
Justin182 Car BMW M3 Dec 24, 2006 #4 Is it he strut top nut?.. can you turn it with you fingers? The whole strut will have some play in it and will spin if too much force is applied when tightening it.
Justin182 Car BMW M3 Dec 24, 2006 #5 Just read you said by hand... shouldnt do this mate. You sure its on right?
fUbAr Dec 24, 2006 #6 21mm deep socket... get them tightened up! its not a BIG problem as the weight of the car keeps the struts in place, but you dont want them hand tight! lol nip them up until you feel the resistance... the strut will spin when its tight enough as Justin says.
F Fred@BTM Car Lionel Richie Dec 24, 2006 #7 tighten gentley til you feel resistance form the spring, if you go to far you've fucked up!
